so i installed the Diablo Trinty basic diablo tune on my truck today. after i ran it i saw that you could make other changes so i changed the tire size to see if id get better gas millage and when i went to install the tune i made it says the last tune did not finish the original will be restored and wont let me restore it. it says unable to restore to original back up PCM:error unlock for reflash(-1) i press continue and then the same thing keeps happening.
my truck will turn over but will not run it in the with key to the on position all the message center shows is a alternating flashing battery and SECURITY can someone please please help me im left with no transportation and i cannot contact diablo tech support until mon
Your truck/tuner can only have one tune at a time, you must reset to default every time you make a change and then re tune. The tire size ( diameter-or height_)will only help make your speedo more accurate. Reset to factory and start over.. Make sure the tuner is re booted ( and unplugged) or the program before re tuning..
Make sure all conditions are met ( doors closed, lights off or on, and the gas pedal and brake clear and only pressed as needed and as far as needed.
Good luck
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,164 Guests (See full list)
