8.1 Misfire Trouble Shoot
shu-dog
I have a 2001 GMC Sierra 2500HD 4X4 with 8.1 and Allison Tranny.
Having serious misfires in overdrive under load. Also backfire through intake.
Most noteable at 50mph going uphill in overdrive or drive with/without tow/haul button.
Truck has 115K miles on her.
I replaced spark plugs 20K miles ago
Plug wires and coil packs within last 3K miles when I noticed it getting bad
ALL 4 o2 sensors just done
Still doing it.
My plan next is to do a Leakdown/compression test.
Anything else I should look at?
Im assuming leakdown/compression test will tell me a lot.
What numbers should I see?
Back when the 305 engines came with chocolate camshafts one of the symptoms was back firing in the intake under load. You may want to pull valve covers off and take a look at the amount of rocker arm movement while cranking engine over. You do not need to run the engine to see this.
Keep in mind the three things required for an engine to run. Fuel, spark and compression. You say it is intermittent, so you can pretty much rule out a compression issue. Low compression caused by a mechanical issue will always be present. You changed the plugs 20k ago, was that done in an attempt to address this issue? Take a good look at them when you pull them for the compression test. If you have a buddy giving you a hand, you can accomplish a good amount of trouble shooting during compression test. You can verify plug condition, you can verify camshaft still has lobes by removing valve covers before compression test is performed and watching rocker arm motion during each cylinders compression test, and you can verify compression across all cylinders.
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
