Mothers Day
Stepside Z
I just thought to myself today holy $hit mothers day is comming and I have not gotten my mother a card. Don't make the same mistake I did.
:eek: That's Right !
Mother's Day is on May 11th, that being Sunday that is! Don't forget the wife also. After all SHE is the MOTHER of your children
The card is VERY important. Don't forget the card. As a mother I don't mind if I don't get a present(don't get me wrong a present is great) but I really get sad if I don't get a card.  I just want to say one thing. It only takes a minute to call your mom and tell her you love her or go up to her and give her a hug. Do it. This is a hard time for me because I lost my mom 3 years ago and seeing everyone shopping for mom and all the mom stuff on tv... it still hurts. I don't want to bum anyone out...I'm sorry. Just love your mom...EVERYDAY :thumb:
