FS ton of stuff from the 14' Ltz truck
1) OEM Projector Headlights with FX-R Projectors retrofitted In Good condition. There are small amount of dust inside from the retrofitting. SOLD
Come with Morimoto Ballast, Relay harness, capacitors and a pair of 5000k D2s
2) Pop and lock for Silverado/Sierra SOLD
3) Eagle Super awesome Led tails for Silverado only. Was on my truck less than 3 weeks before I traded: SOLD
4) Like new condition Illuminated Black door sill kick plates: $200 shipped within US
5) Headlight switch bezel pod can fit 52mm gauge: $70 shipped within US
6) Brand new FX=R projectors 3": $100 shipped within US
7) Black heated leather steering wheel: SOLD
IMG_9149_zpsqq4bbm98.jpgIMG_9150_zps7p4gtfgg.jpgIMG_9151_zpsfe4vxdqb.jpgIMG_9153_zpsfiwklln8.jpgIMG_9154_zpsfx9kvz8o.jpgIMG_9155_zps9ueqkjh6.jpgIMG_9156_zps8riy0vog.jpgIMG_9157_zpsjmfvejp0.jpgIMG_9159_zpsawabrooh.jpgIMG_9160_zpssrggjkl6.jpgIMG_9161_zps4xbcowku.jpg
Running lights
Brake lights
how does this heated steering wheel work on a truck without factory heated steering wheel??
interested if this can be added
Check in the how to instructions. There is a way to do it.
Sent from my SM-N900V using Tapatalk
Headlights SOLD.
What color do the kick panels illuminate?
Same color as the interior color, dash radio knobs, buttons etc.
Yes it is can be added.
There is the thread in the how to section.
Sorry for the threadjack but man.. what company made those tails? Tried hunting around but couldn't find the exact thread.
Message headed your way on the FX-R regardless.
The tail is Eagle eyes led tails V2. Search Ebay.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
