14 hours ago, ajevan21 said:
@Zebrafive Is there anywhere you know of to buy this harness? Or where to get the parts I can buy to make it myself. I believe I found a black one instead of green from Delphi but unsure of the other connector in which I need.
Dephi made the connectors, but they had a name change. I don't recall their new name, but it starts with A
You can buy the connectors, terminals, locks all from www.mouser.com
Do a search in connectors> (brand) > 2 way for the light green one, and 8 way for the black one. They have pictures of all the connectors they sell. Once you find the connector, click on it and it will show P/Ns for the terminals (several offered, 1mm squared is what I used, that is the wire size converted to mm squared) and the lock.
I used 18ga wire, 26" long. That was the largest wire gauge that will fit in the light green connectors. You could go lighter wire.
Lt green connector A = Red, B = Black
Black connector 1 = Black, 7 = Red
I no longer have the P/Ns from when I built harnesses.
  • 1 month later...
Man thank you for all that. I have one more question, is pvc 18awg okay or should I get something higher rated like gxl/sxl etc?
Insulation should not make a difference. The better insulations are thinner to save weight and space. You could probably even use 20ga wire. 18 ga was the largest I could fit into the light green connectors.
Edited by Zebrafive
added information
Aptiv is the new name for the connectors, at least from what I can tell from mouser.com...
Make sure to get the right crimping tool if you are going to crimp new connectors to bare wire.
    erickn520
    erickn520
  • Who's Online   3 Members, 0 Anonymous, 1,729 Guests (See full list)
