2016 4WD SLT 5.3 Vibration 45-50mph
I read through the Vibration thread, and it is VERY extensive, toward the end the water gets rather muddy ;-) Can someone point me to what could this issue be, 2016 SLT 4WD 5.3L vibration comes and goes around 45-50 MPS and it feels almost like I am running across the warning ridges on the sides of the highway that warn you you are leaving the roadway, or the roadway warning on rule roads when you are approaching a stop light/sign. The vibration can be felt through the steering when and the seat, and resonates through the cabin, but it is not constant and does not occur all the time. Mostly when I am running a steady constant speed for long periods of time. Next week I am taking it into the dealer, but wanted to be more informed rather than relay on just the dealer for an explanation.
My truck is in the shop now. Service advisor stated that there are several bulletins out and they are talking to GM. You should go to the dealer for service. I recommend writing a detailed description and take it with you to dealer. It helped my mechanic focus his efforts vice using a vague description on the service ticket. Good luck since a definite fix has not been found.
Do you have an 8-sp transmission? A torque converter issue. PIP 5337A double flush and change trans filter.
some customers may comment on any of the following conditions:
A shake or shudder during light throttle acceleration, between 30 and 65 mph steady state
driving.
Excessive engine RPM fluctuation that may be described as frequent tachometer needle
movement at constant speed when engine speed is below 1600 RPM.
A shudder feeling that may be described as driving over rumble strips or rough pavement.
It is important to note that these conditions:
Do not occur during vehicle launch from a stop.
Do not occur when the transmission is shifting gears.
Do not occur when the vehicle is decelerating.
Do not occur when TCC slip speed is zero. TCC slip speed is zero in gears 2-8 when engine RPM is
greater than l600 RPM.
These conditions may be caused by an internal torque converter issue,
A revised torque converter that addresses these conditions will be available soon.
This PI will be updated with more inforrnation and the P/N when these torque converters become
available.
Current service transmission assernblies do not include this revised torque converter,
Replacing a transmission to address these conditions may not correct the condition and is not
recommended.
I've experienced a vibration on occasion with my 2015 and now 2016 that vibrated the entire truck for just a second or so. In both trucks it has something to do with going into V4. Try looking to see if it's switching over when it vibrates. I'm not sure if yours is continuous or just quick like mine. On my 15 I tuned it and shut off the V4 mode and never vibrated like that again. It's strange how it only does it once in a while. I know there are other bulletins as mentioned to flush as well. One thing you could try is put it in manual and shift it to 7 I believe and it will keep it from going into V4 just to see if the vibration goes away. This will tell you if that's what's causing it. I know on my old 15 if I put it in M5 it would operate this way. I've yet to try manual on my 16 but I think it's the same way. Hope this helps. Let us know how things turn out.
This sounds EXACTLY like the issue thank you! and yes its the 8 speed tranny thank you I will contact the dealership.
driving.
available.
recommended.
