Moisture in LED Roof Marker Light
Center LED roof light on a 2011 Silverado 2500HD
I noticed some moisture inside the lense. Anyone ever run into this? I wanted to take it off and attempt to fix it if it's possible.
Thanks
Matt
Yes you can pop a lens off, be ready to clean up and clean well, use black RTV on the gasket. I would leave it off a bit and dry it out, Roll down windows and run a hair dryer in the hole for a bit on low. With lots of RTV and Lens back on, put some RTV In the bolt holes, install the screws/bolts into the clips, then RTV OVER the bolt heads. Make sure the bolt heads are cleaned with alcohol, and the Lens too in that area. Common problem, should be able to fix it. Mine did it, and after I have no issues with a automatic car wash... Good luck
  • 1 year later...
I believe all that's left is friction that's holding it together. I would suggest a screwdriver in the edge between the lens and the rubber pad to pry it up. Shouldn't take a lot of force.
    JustusTX
    JustusTX
  • Who's Online   4 Members, 1 Anonymous, 714 Guests (See full list)
