2007 GMC outer front axle boots leaking
About six months ago I installed some bilsteins 5100's At the same time I installed new upper and lower ball joints. At this time the axle boots was not leaking. The other day while changing my oil, I noticed both outer boots slinging a small amount of grease. My truck has 130,xxx miles on it. Who thinks installing the bilsteins caused the boots to start leaking or have they just worn out. Either way is there a particular replacement axle brand anyone would recommend or just pick up a set from advanced with a life time warranty. I'll be installing both soon. Thanks!
The bearing and seal in there wears under load so eventually they will start to leak.
I can see how changing the axle angle could cause it to start leaking on an older bearing and seal as it was wearing at one angle then everything changed.
So it was already wore but the change just got it going. You would have and an issue in time regardless. I had a 4x4 Colorado and the front seals love to leak in those.
If it was me would do both of them just so I know they were done and good to go.
This was my thought also. It appears the leak is coming from under the small clamp. I see no cuts or tears in the boot.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 501 Guests (See full list)
