Odd ticking noise and vibration
Coming from mid to rear of truck. Ticking kinda like a lifter noise or gravel coming out of tire treads.
Couldn't get the drive line to move at all, so I don't think it's the u-joints. Started as a tick every once I'm awhile to a squeel and now back to a constant tick and vibration.
It is only when in gear and moving. And then only when I'm on the gas.
I've checked everything I can think of, anyone else ever have a similar problem? Could really use some help on this..
Sent from my SM-N900T using Tapatalk
did ya use a breaker bar to test with...if not come back when ya do
Well I was just asking a friend about it.
Usually I can get a little movement by hand and this time it wouldn't budge.
The rearend on this was fairly well worn when I put it in as a temp fix until I could do the 14 bolt conversion. He told me it's probably bound up so tight I can't get it to move.
I'll open it up tommorow and see what it looks like. Might be a good time to do the other rear end cut/welded. I'll be ordering the conversion u joint tommorow.
Bad u joint, slip yoke needed to be greased badly
+1
    Joegstfsn
    Joegstfsn
  • Who's Online   4 Members, 0 Anonymous, 545 Guests (See full list)
