Transmission filter selection
What kind of transmission filter has everyone been using? I have only seen Purolator, Pro King (or something like that) from Advance Auto, and the GM filter. Not sure about the Advance filter, but the Purolator runs about $30 and the GM about $55. Do I have any other good choices? What about Napa? Many of the folks on the forum seem to like their oil filters.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
