How do I take the door panel off??
Stepside Z
I have some work to do on my 98 Buick Century and the work requires removing the back door panel. So how do I do this? I think it just pulls off but I want to make sure. Thanks for the help.
Remove the armrest and the window crank (if it has manual windows) or remove the window control panel and unhook the wire connectors. Also look for screws around the door opening handle trim. Then carefully pop the clips starting at the bottom and work your way up until they are all off. When just the top is still hooked, sometimes you have to push IN and UP to get it to let go along that top part. Sometimes it helps to have the window down to get that to come off easier, but if its a 4 door, sometimes those back windows don't go down all the way.
Should be pretty easy. Don't worry if some of the clips stay in the door and come out from the panel, just yank them out of the door and re-attach them to the back of the panel before you put it back on.
Hope this helps.
