Rear Axle interchange- what is the difference - Crew vs Ext Cab
Help, I have 2006 1500 Crew Cab. Currently has 3.42 and wanting to go to 3.73 gear ratio. I can fine numerous extended cab rear axle assembly at a great price. The crew cab rear axle assembly is a lot more and hared to fine.
Does anyone know the difference in these axles.
Are the leaf saddles different, the brake type,, etc.
Can you get an extended cab axle to mount up, or are the differences to much to easily overcome.
To the best of my knowledge, the axle itself should be the same regardless of cab configuration. I don't know of any reason why there would be a price difference. Come to think of it mounting should be the same as well. The difference I can see in brakes would be dependent of what year did the axle come out of compared to yours. Earlier 99-02s, give or take, had disc brakes in the rear and yours obviously has drum brakes.
I can find 05 to 07 extended cab rear axles around the $300 price range, correct ratio, locker, and 6 lug. 05 to 07 crew cab axles are all around $1,000.. I have JF3 brake code, BRAKE VAC POWER, 17" DISC/DRUM, W/ABS, 7,000 LBS.
So if anyone could help as to if an extended car rear end would work.
Thanks,
There are 2 brake options, JF3, 7,000 pounds
and JF7, :
HYDRAULIC POWER, 17' DISC/DISC, W/4WAL, 6800 LBS
Is the JF7 still drum brakes. is there any real difference.
Are you able to transfer the brake hardware from the JF3 over to the donor JF7 axle assembly.
OR is there some sort of wheel speed sensor difference due to a different type of ABS.
I found this:
"the jf3 with the jf7 is the brake system part numbers are the same other than the wheel cylinders. The jf3 has 1 1/16th inch bores and the jf7 had 15/16th inch bores."
And I believe I can swap brake cylinders and hoses from the original axle to the new donor axle.
? Does this sound correct?
  • 3 years later...
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 479 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
