Touch of Class?
gnet158
I just got the wife a 03 Catallic CTS & it comes with Leather seating. Since I've never had a car/truck with leather the dealer sold me something called "Touch of Class" that is suppose to protect the leather from any stains and cracking for 5 years. According to the dealer I don't even have to treat the leater because this stuff will protect it. Has anyone had any experiences with this stuff? I need to bring it by so that they can treat the interior and exterior with this stuff. It's garrenteed (sp) for 5 years. If anything happens (stains or cracking) and they can't clean it they will redo the area. Thanks!  :)
