question about the Bilstein shocks
SAKO79
I have a 2014 GMC Sierra 1500 with a Rough Country 2 & a half inch leveling kit I am running toyo m55 LT275-70-18. I'm not a fan of the Rancho Shocks at all and I'm thinking about getting a set of bilstein's and getting rid of the leveling kit. Would it be good to get rid of the leveling kit or just add these? Will taking the leveling kit out and installing these give me enough lift to be clear my tire size now?
I haven't had a chance to install my 2" leveling kit to compare the ride, but I've heard the Bilsteins on the highest setting (to lift it the most) rides rough. I would leave the leveling kit on and add the Bilsteins to the factory setting and you should have a pretty good ride then,
I was thinking about installing the B 5100 adjustibles also. The thing about the Bilstien shocks is that you will get more travel than the RC. Let me know if you want to get rid of you RC 2.5!!
  • 5 months later...
Did you end up keeping both or just going with the belstein i'm thinking about adding a spacer to my belsteins
  • 1 month later...
I've had my bilstein 5100's set at the highest setting for over 8 months now and love the way it rides. It doesn't ride rough at all.
I had the 5100s at the highest setting for about a year and I enjoyed the ride - better than stock for sure. From what I've heard, people have had poor results using the 5100s and a leveling kit at the same time.
Yes, you don't want to "stack" lifts. That will kill your angles. I had 5100's on my last 2 trucks, a '08 Tundra and a '13 F-150 and the overall ride was fair to good, a little stiffer than stock. However on slow bumps such as speed bumps especially, you could feel the shocks "top out" and thud. It was really annoying.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
