GMC 18in Rims
Can you polish the Aluminum rims to a high gloss finish ? If so what can i use ? Thanks in advance.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
