In need of a private offer for GMC!
My truck will be here in a few days. I have been trying to get a private offer and have had no luck. If anyone gets one they cannot use, let me know!
Thanks guys
Use Chrome Web browser and switch to incognito mode. From there go to the gmc website and or their build site. Refresh the page and in a minute or two you will get it. If you have issue let me know when I go home tonight I can try on your behalf.
Sent from my SM-N900V using Tapatalk
I'm having no luck with your method Rock. If you have a chance to try let me know. Thanks.
Nevermind that. I went to a different PC, made sure my Chrome adblocker was turned off, and then went in through Chrome incogonito, and started wandering around the GMC Canyon section, I think I was looking at the accessories page, when lo and behold up came the $1500 PO. This is in the southern NY region. I doubt the PC change had anything to do with it, and I had received a PO on this same PC a couple of months ago, but at the time I had no interest in GMC trucks! Thanks a bunch for the tip.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,255 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
