99-06 charcoal A pillars, battery support and Airbox support bracket a
Looking for below
battery support
dash harness for plugs for lighter and power outlets
Looking for below
battery support
Full console harness or jump seat? And how much of it?
I believe both are the same, just need the orange/blk wire that has harness to plug into the outlets
Post 03, the full console and jump seat had different plugs.
I believe plugs that go into accessory and lighter outlets are the same, I don't need actual console harness
Then after 03 they were different. I did the console conversion and had to change them. Ill see if i have the plugs in the garage tomorrow
Just need Airbox support, got everything else today for $20. Thank you for checking Chris! I need to turn my notifications on shoot
I was surprised i had the harness to completely plug in. No splicing needed on mine. I thought i tore it up during my console swap
how far up the dash did that go? You switched because your 99-02 wouldn't work with the 03+ console?
Mine is an 04. The console came from an 05. But the harnesses were different in the different trims
