4.5" lift with 33's?
I recently bought a 2002 ccsb 2500hd 8.1. It has a 6" lift with about 37" tires on it. Has the stock 4:10 gears in it. I plan on towing pretty heavy with it in the future (right now heaviest thing is my boat at around 5500 lbs) and don't want to strain everything; nor do I want to change the gearing. I've read that the Fabtech is actually about a 4.5" lift with the t bars cranked, so I'm planning on dropping it down a bit and putting on smaller tires. Does anyone have any pics of about a 4.5 lift with 33" tires on it? Not sure if 33's would look too small and I should stick with 35's.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
