Stock Height of 1986 GMC K1500
Hello, I'm trying to figure out how much lift the front of my truck has. It has 2" blocks in the rear and sits pretty level so I'm assuming 3-4" in the front. I was thinking that an easy way to determine the lift would be to measure the ground to fender distance and compare it to a stock value. Mine is sitting at 40-5/8" (front fender to ground). Is that the best way to go about it? If so, does anyone know what that stock value is? I'm trying to figure this out because I need to change out the shocks and want to make sure I get the right size. Any help/insight is appreciated.
Thanks!
FYI here are my measurements for my 1979 K10 4x4 Short bed SBC 400 Turbo 350
Front axle to bump stop bracket is measuring from top of axle tube to metal where rubber bump stop is attached.
Fender to ground measurement is put tape measure align with center of wheel hub to fender on level ground of course.
K10 stock height
12.25 - 12.5 rear axle to frame
9.25 front axle to bump stop bracket
39" front and rear ground to fender 285/75/R16 BFG All Terrain KO2
K10 Tuff county 2" leaf spring height
13 - 13.25 rear axle to frame
10.50 front axle to bump stop bracket
