Anyone delete the oem muffler, flapper, and resonator
Who's take out the muffler resonator and flapper and just throw some pipe in instead of a muffler how does it sound on a 5.3 do you get that mean bark to it or should I just get a Flowmaster muffler lol
Sent from my SM-G900W8 using Tapatalk
I put a electric cutout on mine I love it located cutout before muffler but after all cats and sensors. Best of both worlds quiet when you want it and hotrod when u wanna be heard
I did it on my 15 6.2 Denali. Sounded awesome, no drone and loud when you wanted it. Only downside is on a cold start, the truck was EXTREMELY loud. Luckily I have good neighbors. Something to think about.
I did it, sounds great not too loud unless you press on the throttle and go into the higher rpms that's when it really opens up. ^ agree it can be somewhat loud on cold starts but nothing to crazy
There's a video on YouTube of a crew cab that had it done, it can give you an idea of how it sounds
Did you go muffler or straight piped? I love a loud cold start so that's no issue country boy over here lol
You when with pipe or with the muffler? And no flap
. No muffler, no resonator, no flapper. Just 3.5" straight pipe to 4" tips.
Nice dude I was probably just going to keep the same diameter pipe as oem and then just ditch my pipe
Do you guys have videos of you 5.3 w the muffler, resonator and flapper removed. There are some on YouTube but only 30 secs and don't give the best idea of the sound. was thinking on doing this as the cheapest and probably best sounding way to go
Sent from my Nexus 6P using Tapatalk
On a 6.2 3.5" is stock diameter. I missed the 5.3 part in the first post. My bad.
Thanks dude well I think ill give that a shot in my truck i do have a tuner in i so should maybe sounds pretty good!
I did it and it sounds awesome really like it! Not really much drone and the v4 drone is not an issue either overall way more satisfied like this vs the muffler flapper route
Any chance of a video for the sound?
I'll try and post one tomorrow
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
