Window trim swap
So I got the chrome trim and decided to switch it out with the black. Looks like I broke every single clip lol. So the question is does anybody know where to order the clips from. Or have a part number for them
Bump
Bump
Dealer/parts department can look up the part number for you, if no one on here knows.
After reading all the trouble people have had with these I'm so glad the chrome trim wasn't as common on the 14's
Thanks almboss I ordered 16 of them
  • 1 month later...
I have the chrome if anyone wants to swap for the black. Alternatively, does anyone know the part numbers for the black window trim? Thank you.
I have the black trim off and chrome on. So I the black laying around. Would you be interested in trading the chrome strip on the door for painted. My truck is tungsten metallic. f9e0d3db9770c9441e06eb667717d683.jpg
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 779 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
