Need help trans or rear end
07 z71 crew (new body) automatic The other day i was cruising about 65mph and went to pass a car, when it went to downshift from 4 to 3 it just revved like my tranny was slipping and my traction light flashed twice, only does it when downshifting from 4-3 wot, fluid is full and red, no other problems shifting through the gears and no other lights or messages, any help would be greatly appreciated, thank you.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
