2014+ 1500 muffler delete
Looking to do a muffler delete or flow master 40. I seen videos of the delete that's welded. Can you do it with out welding and use clamps to have the same output?
What do you mean Don't delete the muffler?
I was kidding, I was saying don't just delete the muffler, delete the muffler and resonator. It sounds even better!
on the 5.3 I hear that is the case, on the 6.2 I hear deleting the resonator is no bueno
I deleted the muffler only on my 6.2 over a month ago and I still think it sounds great. The only complaint might be on cold startup (for about 1.5 seconds) it sounds a little sloppy. Any other time it sounds great.
I've heard of you remove the muffler it will mess up the engine because of no back pressure
I agree with deleting the muffler on the 6.2, I plan on it. I just believe keeping the resonator in there is a good idea.
Just did the muffler and resonator delete and it sounds amazing. V4 drone sucks but its not awful.
