Adding cooled/vented seats
What's the best way to add vented seats to 2016 crew cab, with factory heated leather?
While the dealer can change out the seat covers, you will also need all of the ventilation system for the seats. The obstacle will be the programming, I think that is handled thru the BCM and the dealer has no way to change the programming in the BCM to turn on the ventilated seats function.
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
