Truck bed light quit working
I was trying out the lights and one of them is not turning on only the passanger side is working. Do they have separete fuses for them or are they on one circuit. Anybody had same problem? Thanks in advance..
Check the connection for the LED on the drivers side. If you take the LED off you can hook it up to 12v to confirm if the LED went bad or not.
A single "Y" shaped harness connects both sides to the rightmost plug on the near spare tire/bumper area that also feeds the camera. Left and right should have a common fuse.....check the connector at the LED coming from the harness under the rail coming from behind the drivers tail light.
I will check all that today I only found 1 fuse that says cargo lights. If not a trip to the dealer..
Thanks for all the help I'll report back to see what I find....
If one is working and not the other, it's not a fuse. It would cut power to both bed lights and cargo lights. Just take out that side led and test it. Takes 5 mins.
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 407 Guests (See full list)
