08 suburban LT Airbag light
I have an 08 Suburban LT, Had a minor front end accident and the driver air bag went off, the original air bag module could not be reset, I got one from a junk yard that was reset and reprogrammed.
and when a Plug in the diagnostic computer to clear the air bag trouble codes
I get this Fault codes.
B0083-39 Left front impact sensor internal electronic failure
B0083-3A Left Front sensor incorrect component Installed
B0084-3A Right front impact sensor incorrect component installed
it seamed the sensors where bad and one of them was cracked,
so I replace them with Dorman 590-203.
Original sensors had an #15854647 which is compatible with 590-203 Dorman sensors.
and after replacing them with the new sensors i still get the same Fault codes.
Could i got the wrong sensors since there is two types of front impact sensors?
  • 4 months later...
Price
DORMAN 590224 {#25896408} Info
Front; Radiator Support Mounted; Stamped 25896408
$84.79
DORMAN 590273 {#10381278} Info
FitsRear Left; Door Mounted; w/RPO Code ASF
OrRear Right; Door Mounted; w/RPO Code ASF
$120.79
FitsFront Left; Door Mounted; w/RPO Code ASF
OrFront Right; Door Mounted; w/RPO Code ASF
$121.99
AIRTEX/WELLS 5S13659 {#SU15065}
Front; with Stamping # 25896408 (Only 2 Remaining)
$225.79
AIRTEX/WELLS 5S13672 {#SU15078}
Front; with Stamping # 15854647 (Only 1 Remaining)
$301.79
These are the numbers I acquired when I cross referenced your model on Rock auto. i think you have the wrong sensors.
