Misfiring issues and shifting problems
jtdub91
I was wondering if anyone else was having the same issues I am having. I have a 2014 GMC Sierra with the 6.2L. I bought it with 32000 miles on it. Ever since I've owned it it has had a misfire or a backfire when it shifts gears. Not sure which one I would call it. It only does it under full throttle and only when shifting into the next gear. I've had it into the dealership twice now and they tell me that they can't find anything wrong with it. They said since I changed out the exhaust it might not have enough back pressure but it was doing the same thing with the factory exhaust. It's isn't throwing any codes but something just isn't right.
I also have an issue under light acceleration with the transmission. It has a pretty pronounced hesitation before it shifts and seems to shift really early. I've never noticed anything like it with any other GM product I've owned. It doesn't shift smoothly at all. It will hesitate and almost lurch forward afterwards. Anyone that might have any insight I would appreciate your help.
I have a 2014 GMC Sierra with a 5.3 liter I was experiencing the same issues but apparently it's normal according to GM and every dealer I've been u.
I just find it hard to believe that it's normal. I've never had anything remotely close to this happening on any other GM product I've owned.
Hold down the tow/haul button on the end of the shifter for 5 seconds until grade braking is disabled. (Yes it needs to be deactivated every time you put the key in)
Remove negative battery cable and let it sit over night. Reconnect and drive fairly aggressively for atleast 30 miles.
Make sure you're filling up with top tier and premium gas.
you are seeing shift torque management, GM has used it for years. This is very normal, the ECM pulls timing on the shifts to reduce the power output and then ramps it back in after the shift. The early shifting is normal as well, you can blame the EPA on that one and the fact that trucks are now part of the Corp fuel economy calculations for the manufactures.
    C. Hart
    C. Hart
  • Who's Online   2 Members, 1 Anonymous, 592 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
