What kind of ROOF RACK is used on the Z71 Tahoe...
Hey all,
There's a Z71 Tahoe commercial on TV nowadays that shows a Tahoe with its roof loaded up with gear. It appears to me as if this stuff isn't just strapped down to the roof, but that it's sitting on some kind of rack (that must mount up to the existing roof rails). Do I have this right? IS there some kind of rack up there? Or, is this stuff simply strapped to the roof? If there IS a rack up there, does anyone here know anything about it? I like what I see -- despite not really being able to see it too well! :lol:
Any information would be appreciated!
Oh, also, did you notice at the end of the commercial, when a women closes the rear hatch, that a "TAHOE" emblem appears there on the hatch? Maybe they changed the emblems on the '03's, but nowhere on my '02 does that "TAHOE" emblem appear! I simply have a "Z71" badge on the left, and a "CHEVROLET" emblem on the right. The emblem that appears in the commercial strikes me as a SIDE emblem on a NON-Z71 model. Is this just "advertising poetic justice," or did they change things on the current Z71's?
Thanks, folks!
-Kirk
I know there are some trick aftermarket racks available for the Tahoe/Suburban line. They are alot like a "safari" rack.
I haven't seen the comercial, so I guess I really don't know what you are refering to... but maybe GM has seen alot of sales for this "safari" rack, and now they are offering it as a GM accessory.
Thanks for the reply, Shaners! Care to point me in the direction of some of the trick racks that YOU are refering to? Always looking for different options.
Thanks!
-Kirk
PS -- If you DO see the commercial, please respond again with your thoughs.
Check your local bike and/or ski shop for Yakima racks or check them out on-line Yakima. They've got rack systems for just about any kind of vehicle out there!
Out of interest, what exactly is the difference between the roof rack on a Z71 Burb/Tahoe and that of a regular model. Is it just 'cladding' around the rails or what?
Actually, I'd like to know this, too (I'll have a chance to compare them side-by-side soon, but don't know the answer off-hand). It APPEARS to be just cladding; and it sits higher; and it has a roller at the end. However, the actual "bows" that span the width of the roof SHOULD be the exact same thing as on a standard Tahoe, shouldn't they?
...Which leads me to my next question, and that is why a Yakima/Thule rack that fits a standard Tahoe shouldn't fit a Z71 Tahoe. I know that the last time I checked out Yakima's site, after submitting "Z71 Tahoe" in their application guide, it said that there was nothing yet available for this model. How the heck could that be? IS there something different up there? I can't imagine there is.
I haven't checked Yakima's site for close to a year now. Maybe they have something that fits -- or, maybe they've had something ALL ALONG tha fits that they didn't distinguish as being able to fit BOTH a Z71 and a standard Sub/ho.
Can anyone shed some light here?
-Kirk
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
    • You refuse to own anything made in this century yet you reportedly own... a 2007 Silverado, which is now almost 20 years old. The dissonance.... turn up your hearing aid?   You clearly don't understand the government contracting process, brother. We send people to die on front lines, keep the public safe, and make people's husbands, wives, children enter burning buildings with equipment from .....wait for it.....   ...the lowest bidder....   Just because something is used for a long time doesn't mean it's good. But it might be cheap and plentiful.   Please, continue to whine about new trucks in a thread dedicated to new trucks, which you've said you'll never own. We get it. Go tell everyone how you're stuck in time on a Panther forum. I mean, Jesus, an 86 isn't even one of the good Panthers.
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
