2016 Silverado Bulb replacement
Is it possible to replace just the headlight bulb on the HIDs??? I would like a whiter light output like the the LED headlights. I drove a LTZ at night and fell in love with the white light output.
Thanks
Thanks
It's a d5s bulb so unfortunately unless you want to change out the projector, ignitor, bulb, and ballast you're stuck with what you got. The only white d5s bulb I've seen is a cheap China bulb that's 6000k, and a lot worse performing than your stock bulb. Due to the different build of the d5s switching to another bulb would mess up the way the light is projected. They run d5s so the led lights appear as a greater upgrade imho.
