Cheapest you can get a new Silverado??????
kickinasphalt
Well first off I should say I'm new to this board. I currently own a 98 Pontiac Grand Prix GTP. I'm thinking about trading it in toward a Silverado. I don't know if I'm gonna get a new one or not yet (also haven't decided between reg cab short box or extended cab short box). I know GM was doing $3000 cash back recently and I read they might do something similar doing June too. I was curious to know how much you have knocked off the sticker price (including rebates). Thanks.
Yes, I do believe you can get stick-shift V6 regular cabs for $13k-$14k.
How did you get the dealer to shave off an additional $3900? Thats kinda what I'm asking. I'm really not interested in getting the cheapest Silverado, just how much you can get off on a new one.
I didnt have to do anything that was just the deal when i went to buy one, well actually I wasnt really planning on getting a new one until i looked at a local dealers website and saw the markdowns, so i went ahead and traded my 2002 2500 HD in for this one.
kickin, go to www.kbb.com. Click on new price. Then build the truck you want. There will be 2 prices listed, MSRP and invoice. You should expect to pay invoice. Then the rebaites come off of that. If you then click on get a quote, you will be put in touch with a fleat salesmen at your local dealer. Good negotiaters have been known to get the truck for under invoice.
