Crimson Red Blacked-out
I just bought a '16 Sierra SLT in the Crimson Red and was thinking about blacking out the running boards, grill and all the other chrome pieces. Has anyone done this or similar. It started looking at the stock GMC logo on the tailgate that is Red, but not the Crimson Red, it bugs me. Post pics of your blacked out Truck.
