WTB: Wheels
bersh
I'm in the market for two sets of wheels. The first is a set of 17" wheels for a 2004 2500HD. This is for my old truck which is now just a plow truck, so don't need to be pretty but need to be functional and not pitted/corroded so they hold a good bead/air.
The second set I'm looking for is a set of 18" wheels for my 2015 GMC 2500HD.
Thanks.
I have brand new set of factory 18's ,I took off my 2016 Silverado 2500hd no tpms sensors. includes all lug nuts. Would these work
  • 1 month later...
Just a heads up. Pretty sure GM changed the 8 lug pattern on 2015+ HD trucks.
EDIT: 2010 and older GM HD trucks have the 8x6.5 bolt pattern.
2011+ GM HD trucks have 8x180mm bolt pattern or 8x210mm if a 3500 dually.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 950 Guests (See full list)
