Installing tuff country 4 inch lift.
I read a lot on the forums and have searched for my answer but I haven't found it. I'm installing said lift and I am not trying to get the differential lined up. Right now the differential is resting on the frame where the cross member was. I do not have the cross member installed. The directions say that you do not have to cut the frame just the cross member.
I think the differential is turned, I can not figure out how to turn it back to the position it's supposed to be.
This is on a 2015 Silverado crew cab
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 290 Guests (See full list)
