Protectants
JonesNTN
Which Proctectant do you prefer?
19 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Armor All for me. I've used others and for the interior plastic it works nice.
I do however like the STP Son of a Gun tire shine. The 'spray on walk away' type. It's the cheapest and works great. :D
I usually use the cheapest I can find for the dash and stuff, right now its Westley's. I also like the STP tire foam though, thats all I'll use on tires!
Meguiars Natural Shine has been my choice for interiors for a while. Goes on easy and isn't messy, yet leaves a good glossy finish- but not too bright in the sun.
303 Protectant.
goes on tires nicely and leaves no greasy residue and leaves a nice flat black finish, not a very glossy one. Keeps weatherstripping and black plastic trim pieces from fading as well.
Kinda pricey at about $14.50 for a spray bottle, don't know the size offhand but about the same size as the Mothers Protectant.
Great stuff, worth the money.
I use the Pledge orange wipes inside the cab. It smells clean and looks good. It picks up the dust and smudges quickly.
On the tires and rubber outside I have used a lot of different products.
Lately I've been useing Turtle was Formula 2000 foam.
It lasts a long time and doesn't rub off on your clothes if you rub against the tires or trim.
At work I have been useing ZEP tire dressing. It gives the tires a nice deep black look and is easy to apply.
I might switch to that product at home when the foam runs out.
303 Protectant. :D It is the best stuff going. Armor All is a silicone based protectant. Over time, it will dry out the plastic and turn it white no matter how much or how often you put it on. It will also cause tires to crack and dry out.
Here here.
303 rocks. It is really big in the boaters world and that world has some really harsh enviroments on the lakes and Ocean where the sun is magnified by the water.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 382 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
