Lift questions
Paulybee
What's the difference between the fabtec and mcgougys (I know I spelled it wrong) other than the Uni ball? What one is better? 6 inch lift nothing To crazy
One is cheap one is not. 6 inch is actually right at the start in the range where a lift kit would be considered 'crazy'. Sure you can ho higher and harder but 6 inch will change all the angles enough to require specialized components.
You Lift It You Bought It
warranty should also be considered. low end kits you are on your own and GM can easily point to a lift as a drive train failure cause. better kits will provide a warrenry for your drive train should GM deny a claim.
I was figuring like 4 grand ish for the kit. Just not sure if there is much of a diffrence in the 3.
For that price range I would suggest looking at the BDS Coilover kit it run around 3800 but you may find a sale. They provide a no nonsese warranty but it must be installed but a certified/affiliated installer. This is a 'better' kit in that it does not use spacers like lower end ones and should come with control arms and add a leaf.
Pro Comp Stage 2 lift is equally as good as is their warranty and also does not use just spacers. It is around the same price give or take a couple hundred. They are however completely out of stock and from what I know have no ETA on availability.
*I am not an expert nor would I consider any online advise as such myself. We are all just enthusiasts take it as that but at least you can ask the right kind of questions when talking to a pro in a shop.
**Expect to pay 8 hours, possibly 10 in labor at whichever shop if you want to keep warranties in tact you cannot install it yourself.
I'm leaning To the bDs just for the warrenty they offer. I'll end Up using the jacked Up truck as my Daily. Somethjmg will break sooner or later. Lol
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
