Rear seat frame access
NB-Nate
I have a 2014 Sierra 4 door and am planning on using the underside of the rear seat to mount a gun rack for when the seat is folded up. I would like to access the frame of the seat by removing the material underneath, and am wondering he best way to accomplish this. Has anyone done anything like this? Hoping someone can point me in the right direction, sorry if this has been covered already. Thanks in advance!
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
