And this is right on there site? Is it for all tires? Just specific tires? Does it have to be two? Or is it just $400
Sent from my Z981 using Tapatalk
This is on ebay, in the discount tire store. It's anything they have in Stock, tires or wheels. I've done it on both.
I'm cheap as any of us lol wouldn't put brakes on my truck till I found them for less then $275 ended up putting some plotted drilled ceramics on it all the way around for $215 from eBay put 25k on them so far still feel the same as day one put them on and still beefy
I find stuff so cheap all the time glass packs and cat back exhaust $210 3" front lift 4" rear block lift $280 with shocks. Both front bearings for my 3/4 ton $120 head light and turn signal assemble both sides $65 I'm gonna have to look into this eBay tire thing now here's a question though I want to oped rims and tires from them I want them mounted and road forced ready to go. Is that possible through eBay?????
I tied back the fender liners and zero rubbing.
Well, after looking at both the 295/60R20 and the 275/65R20 I think theyre pretty close in size.
295/60R20 = 34.29 tall and 11.5 wide
275/65R20 = 34.5 tall and 10.9 wide.
Think I'll have enough room to fit the extra quarter inch in height?
Yes yes same we kinda just took this thread to a conversation between the two of up lol sorry.
I have them on my 15' with 2.5 RC lift.
It's going to be pretty tight!
Awesome, exactly what I was wanting to see.
Any problems with rubbing?
It's does rub very little at max turn. Only on the right side thought. Not enough for me to worry about.
for anyone running these tires did you take a pretty good hit with your mileage or are they not too bad?
What size did you run on these? I'm thinking the same tire with a ReadyLift 2.25" leveling kit on the stock 20's
On 11/2/2016 at 7:26 PM, Bayou-AllTerrain said:
I run the Pro but not that size. I have the 295/60R20s on factory wheels and 3.5" Lift. I like the tires. They are a little louder then I'd hoped but not bad for MTs.
Did you like your STT Pro’s? How many miles did you get out of them?
    scotthvac.net
    scotthvac.net
  • Who's Online   1 Member, 0 Anonymous, 458 Guests (See full list)
