Possible bad right rear rotor?
I feel a shake and shudder coming from the right rear brake after a hard braking incident. It seems to happen when you hit your brakes 2 or more times in a row....such as coming down a hill. It happens at highway speeds, not like crawling. The dealer said they would turn the rotor first, then if this didn't work, they would replace it. Truck is a 2015 with 25,000 miles, so it's under warranty. I don't think turning it will help because it feels smooth...it will make it thinner and when it gets hot it will warp more. Has anyone else had this issue? Should they do both sides?
It doesn't matter how smooth it feels if it's warped. Turning it will take the warp out and it will brake smoothly again You're right, though. The rotor will be thinner after turning and will likely warp again. Just go with it since it's under warranty and hope it warps again while under warranty. There's no need to do both sides if only one is warped. I'm surprised you got this under the warranty with 25,000 miles. I thought the brake warranty was less than the bumper to bumper warranty.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 348 Guests (See full list)
