8 Speed Transmission Issues
I know this has been discussed several times, but looking for any answer at this point. 2016 with 8k miles and getting worse. The 1-2 shifts feel like I just got rear ended. It's horrible and I really hate having a vehicle that drives like this. It's not tolerable. Is there any current fix for this or is my only option to move along, get rid of this truck and get something else?
Not trying to be an ass but, the tranny banging/clanging/lurching, is not going to go away on its own. Mine has done it since new, now with 9k miles on it. Hasn't gotten any better or worse. It's not going to change until GM does a software update on the trans programming.
I just took my '15 in yesterday with the exact same issues and they said there was a new "update" that they ran. sounds like im updating a craigslist app on my phone. anyways, this is the second time ive brought it in the last 4 months and i get the same response... "its normal with these 8 speed transmissions, they are a learning transmission and problem should work itself out..." i call BS and for a truck that costs this much i should have a smooth ride, not like a 16 year old learning how to drive a stick.
I have a 2016 with a 6.2, the transmission had been making banging noises as others have written about. At about 15,000 miles I was driving at about 60 MPH on cruise control and no load. The truck had a loud internal noise that shuttered the truck. Other transmission shutters occurred on a regular basis. Brought it to the dealer and they said the GM bulletin stated it was normal. After that consist banging started to occur every time I went from neutral to reverse along with significant jolts at various points of shifting. I attached a GoPro to the undercarriage to record the violent actions of the drive train and had my wife record rpm's on the dash during shifts. I called the service manager and said this needs to be fixed. Got the truck in and needless to say a week later I had the truck back with a new transmission. I can only describe the shifting at this time as "magical" it is perfect, just a dream to drive. Unfortunately I drove it another 750 miles and the check engine light started flashing along with the stability light. Bad injector on #6 cylinder, but that's another story. I sould have it back in the next day or so. I have owned a 2012, 2008 and 2005 Sierra Denali and even with these issues it's still the best most comfortable I've ever driven.
  • 3 weeks later...
my 17 will down shift and do it slightly if i let off gas before it shifts but i test drove one that was horrible it felt like i got rearended, they rushed it into the shop after we came back but i didnt stick around to see why it did it
    FiLo
    FiLo
  • Who's Online   6 Members, 0 Anonymous, 642 Guests (See full list)
    • sorry to bump an old thread, im a bit clueless with this stuff, would these fit a 2019+ Silverado? https://wiperpro.com.au/products/chevrolet-silverado-wiper-blades mainly wondering if the beam shape stays planted at highway speed, thats what seems to let the factory ones down imo
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
