Retrofit Help
Skelly
Hey guys, I recently purchased a Morimoto Mini H1 projector kit and I'm getting ready to have them put in. I've been reading the topics here and there's lots of good info, however I think I'm missing a piece that will prevent flickering of the lights. My question is, is it a "canbus" or a "capacitor link" that I need? The truck is a 2014 Silverado LT (Reflector housing)
Theretrofitsource offers two different products but I need to know which one I need to order.
Canbus:
https://www.theretrofitsource.com/canbus-morimoto-standalone.html
Capacitor:
https://www.theretrofitsource.com/capacitor-link.html
Thank you for your help!
Capacitor link is what you need. I have mine on my passenger side. Works great.
Thank you!
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
