2008 HVAC Question
2008 SIERRA DENALI -
Question - when I put press the AUTO button on the A/C Heat controls the snowflake button lights up even if the temp is set at a warm temp - is that normal?
Also trying to find out how I would know if any of the door actuators are broken?
Both my Denali and my Suburban do the A/C light when I hit "Auto," so, yeah, I'd say that's normal.
If the doors lock and unlock properly when you use the power locks or remote, they're working. When I bought my Denali, the rear driver's side door wouldn't unlock. I bought a new actuator off Amazon and replaced it myself. Mildly irrititating, and it helps if you have smallish hands. Probably took me 30 minutes, and I'm quite the expert at removing the door panels.
I did mean the actuators in the HVAC system.
It seems that sometimes the Left side (drivers side) blows cooler air when the heat is on and warmer air when the A/C is on, i thought I had fixed this when I replaced the HVAC contols but I think i still have issues.
Bought my '08 Avalanche in 2012. Wasn't completely satisfied with the cooling, so I did some research.
Found out there was a fix that involved re-programming the HVAC system. I paid a fee to have the computer re-flashed. Seemed to improve, after that.
Wish I could tell you exactly what the symptoms were. It was too long, ago.
A dealer or another enthusiast may be able to help. They would probably ask how long you owned the vehicle, & when the problem started. Here's something: GM HVAC Actuator Recalibration
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,025 Guests (See full list)
