K1500 5.7 94' stalls in gear
Ok guys and gals. I have a 94' blazer with the 350 TBI and this problem has started a week ago. It would die when at operating temp and at idle with no load on the engine. I concluded the ignition control module. After replacing that, the engine would stall only at idle with a load. With the symptom seeming to be improving, I found the idle air control was out of range (a-b @ 83ohms) so I replaced that. The problem has not changed at all. At idle and with a load she hesitates and dies, almost like it's a fuel delivery problem. Only engine modifications is a set of headers and a throttle body spacer, ( both where on when I bought it in August.) My manual says it could be the ECM. So before I let this beloved truck sit until I can afford one I figured I'd get on here and see if anyone could inform me of anything else it could be. When running, there is no hesitation or lag, strong truck and strong responses. She has 180k+ on the odometer.
  • 2 months later...
I have a 891500 gmc blazer it is doing the same stuff i have changed everything but the throttlebody and the fuel filter and the fuel pump i was wondering if the computer would be the problem can you help if you find out any thing
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
