Hi everyone,
I know this forum hasn't been active for a while now, but I was looking to add Onboard Air on my 2014 Silverado 1500, and this was the first, and one of the only, forums I saw for Silverado's Onboard Air.  However, I did not find a direct answer to my question...
When I switched over to 35" tires, I had no use for my stock spare, so I took it out and thought that would be an ideal place for Onboard Air, since there is ample room to work with and its all accessible.  I looked all over the internet for someone who put an Onboard Air setup in the spare tire location... and all I found were kits that started at $1000 and only went higher.
I decided I would get a Viair Onboard Air kit, and make my own affordable mounting solution.
I designed a mounting system that utilizes the spare tire location and existing bracket, in which my plate and spacers are bolted to.  My plate is made out of laser cut, 10 gauge (0.135" thick) 304 Stainless Steel, which is quite oversized for the overall weight of the Onboard Air system, but very high quality.  Stainless allows for the plate to remain unfinished and not have the ability to rust.
I attached a few pictures of my overall setup (pressure gauge, switch, and air quick disconnect may be located wherever you choose).  Hopefully this helps more people, like me, who were looking for different options or something more affordable.
If anyone is interested in replicating my setup, I can make a video or write a How-To on my process for installing and routing all the wiring.
Please send me a direct message if you're interested in buying a mounting plate, they are cheap and become even cheaper if there's a large order!  I can also modify it or make a custom layout if you have your own mounting solution!
*The Onboard Air System used is Viair PN 20002, but the mounting plate works for many other Viair systems*
On 2/4/2022 at 1:22 PM, HeavyOnTheChevy said:
Hi everyone,
This is easily the slickest onboard air install I've seen. I am looking to do something similar and will be referring back this.
Let me know if your interested in this mounting setup, I have the stainless steel plate you can buy directly from me, and I can post exact part numbers for the Viair system and the few misc. parts, if you want the quick disconnect and pressure gauge how I have it!
what was total cost ?
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
