2000 z71 driver seat problem
Hey guys before I posted I read and searched on the subject but none were quiet like my situation. My problem is my drivers seat is electric and all switches have stoped working expect for the lumbar suport. From what I could find other people's seats just stop working all together. Heated seats don't work either. I checked all fuses and replaced the relay for it ( big silver fuse) if it's not a relay not sure of the name. And still nothing. Any idea what could be wrong? Passenger seat works fine. Both do have the notorious 1/4 inch of play when stoping and taking off unless the seat is all he way back. Any info of where to start would be great
Thanks
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
