Text alerts still come on?
fedmogul89
I clicked the text alert button to "off" yet i still get text alerts for some reason. Anybody else have this issue?
  • 5 months later...
Did you ever get this figured out? I just got done fixing mine from the opposite perspective, I was not getting any of them.
Did you turn off "Show Notifications" on your phone? Settings --> Bluetooth --> Chevrolet MyLink (tap the info (Circle I) button)
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 1 Anonymous, 549 Guests (See full list)
