steering problems
superlooper
my truck is really messed up right now. when i turnthe wheel at low speeds it pulls really hard back the other way and wont let my wheels turn. it is making a clunking sound when i turn my wheel also. i dont know why but it just started today and is kindof scary to be driving. i checked my power steering fluid and thats fine, but i dont know what else to look for... its hard to explain but its definetly not normal.. any help?? amy 95 chevy k1500 6'' lift, 33s
Sorry to hear about your problems.  I would try not to drive it until the steering components are checked out, like the balljoints, tie rods and tie rod ends, idler arm, pitman arm.  Maybe you will see something obvious that is broken/cracked/bent that is causing the problem.  Something in the power steering box could be broken also.
Good luck.  I wish I could be of more help.  ???
How many miles are on your truck?  You could have a lot of components worn a little bit, but when combind, causing your severe problem.
    250.3k
    pimafe6931
    pimafe6931
  • Who's Online   1 Member, 0 Anonymous, 727 Guests (See full list)
