2016 6.0 pinging
Ive got a 2016 2500HD CC 6.0 that is pinging under light throttle.It alsost seems like the truck lugs down to much before a downshift.Ive tried different octans,gas stations and it has been to the dealer which of course they said it was all fine...My thought is a modern engine shouldn't ping.Any help would be great
I'd say it's because GM has got these trucks ECM tuned too lean for better fuel economy. I'd bet a aftermarket tune would help out. Hope you get your problem figured out.
Daniel
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
