Looking for a decent cam was looking at voodoo lunati cam in particular the boosted one since i might go procharger but idk if its a big cam for a 5.3
Voodoo Nitrous/SuperCharger Hydraulic Roller Cam & Lifter Kit - GM V8 LS GEN III/IV 286/298
Truck has built tranny with 3200 stall has long tube headers and cold air intake.....
At the time of installation of cam i will keep the stock heads but will port them...
