Hello, I'm new here, this may be already be asked and I'm sorry if it is but will 305x70R16 tires fit under a what seems to be stock 2003 GMC Sierra 1500HD? I'm thanking about purchasing this truck and I won't to beable to up the tire size and give it a little aggressive look. Thanks.
They will fit if you turn the torsion bars up which is pretty simple. You may still rub a little, but that's nothing a box cutter can't fix and it will be so minimum you probably won't need to cut much.
To turn the torsion bar up just turn the 18mm adjustment nut (2) clockwise. I wouldn't bottom the bolt out. Leave a thread or 2 IMO.
If you do that, be careful about your CV angles. If more than two convolutions are touching, it's too much lift.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,276 Guests (See full list)
