Plastidip durability
Vol4Ever
I painted my rims one color and hated it and it peeled right off. I used 4 layers and 2 clear layers. Put a new color on and have had it on for over 12,000 miles with no problems. The key is to not have any "edges" where it can start to peel. I turned the rim around and painted a quick coat on the back side "edges" to get the edge completely covered.
What kind of mud flaps are you running?
Thanks in advance.
Thanks in advance.
They are the GM ones that the Dealer had on it when bought.
2nd thing i did was dip my bowties, this was june of '15 .. they havent peeled anywhere yet after numerous auto washes, me pressure washing several times, along with hand washes scrubbing.
I applied i think 4 coats of black and 2 or 3 of clear
